Hi all
Thought I had fixed the fuel smell problems on my bay. Anyway, my van still smells vaguely of fuel, especially on hot days. If I go for a drive, there is a definite smell of fuel when you walk past it. I've traced this to the fuel breather pipe which is venting into the fuel filler flap.
I've now removed the tank, and I can find no explanation for this at all.
Tank is fine, no leaks. No leaks on the flexible lines to it, either. The breather connections on the metal pipe in the picture are all OK, and do not appear to be perished at all.
Bit of rust, but nothing major.
The smell, when the breather is all connected up, is definitely coming from here...
but it is strong enough to make it possible to smell petrol as you walk past the van :?
The only thing I can think of is that there may be something here...
Where the pipes disappearing up behind the rear 1/4 panel. But I don't know what / where the pipes go?
Any suggestions? I'm doing my head in here, and it needs to be back on the road pretty soon
When I slosh the tank around (not in the van) the fuel breather hose does make a strong petrol smell, so I'm wondering if the breather just is not restrictive enough?
