fuel gauge / sender woes
Cali-Bay
Jan 6, 2007
109
ok, i had the fuel tank out the bus & while it was out i replaced the sender as the gauge has never moved since i had the van.
Before putting everything back i checked that everything was working ok by connecting the sender up & tilting it so the float moves up.
Sure enough the gauge registered fine when i tilted the sender so i bolted everything back in.
The problem is now the needle moves very slightly & is only just visible when the ignition is switched on & doesn't move from this spot no matter how much petrol is put in the tank .............. turn the ignition off & the needle disappears from view again ! :?
Any ideas , i ran out of petrol again today :(
Near bottom of link page "how to" check gauge
http://www.nls.net/mp/volks/htm/fuel_ga.htm" onclick="window.open(this.href);return false;
Alas over the years I've settled for the randomness of VW fuel gauges as my bus never reads full &
drops from1/4 to empty in a flash :shock:
will be investigating a bit more at the weekend, cheers for your reply :)
