Fuel hose clamps
Mark6455
Aug 4, 2010
1,590
Wirral
I've fitted all new fuel lines when I moved the filter above the gearbox but I used jubilee clips but I'm not sure if I should have I think the pipe is 5mm so should I use proper fuel hose clamps for safety
Thanks guys
Mark
as far as i'm aware the correct pipe clips grip the fuel line symetrically where as jubilees are slightly awkward due to the knuckle.
atleast you put clips on......i've seen some who have used the crimp on type yet you can still turn the clip even after crimping it up tight? :oops: :oops: asking for trouble imo.
Absolutely!!! Get rid of the jubilee clips ASAP, they don't tighten uniformly around the pipe unlike fuel clips. If this happens you may get gapping, if you catch my drift.
5mm internal diameter sounds a little restrictive as well.
What size should I be using at the mo ive got a pict 34 boca but should be getting John the horses twin kadrons end of the month
Thanks dudes
http://www.ebay.co.uk/itm/ws/eBayISAPI.dll?ViewItem&item=220627923962#ht_1626wt_922" onclick="window.open(this.href);return false;
