I'm struggling a bit here, and could use some help from an expert. Please be patient with my ramble, in case any of it helps.
I've got an oil leak on my standard 1584, which appears to be coming from the pin on the fuel pump.
When I'm driving, it will dump a load of oil. If I stop and clean it up, it will be OK for ages, but if I leave it, it just leaks and blows smoke everywhere (apologies to anybody travelling from Vanfest to Swindon yesterday). Maybe cleaning it up pushes the pin back in to a place where it doesn't leak ?
Anyway, did the obvious thing, and bought a new fuel pump. However, when reading up how to fit it, the manuals say to put a load of grease in the base of the pump. So if the base of the pump is supposed to be full of grease, how am I getting oil out of that pin ? Is the problem with the gasket, which is letting oil up into the base of the pump ? But then, how is a paper gasket supposed to hold the oil back under pressure ? Do I have a crankcase pressure problem ? (the breather seems OK, but I haven't checked the relief valves)
Tried to get the fuel pump off, but it seems to be a right *** getting to the nut at the back, so I would like to understand as much as possible so I know what to do and can get any extra bits etc before I tackle it again.
