Fuel/starting issue
crede999 said:
68_early_bay said:
Also if it's fuel related, any possibility of debris in the tank blocking the outlet?
Sounds like not enough fuel get the filter out the tank and have a look for crap in the pipe as I bet the filter is buggered and crap is getting sucked into the outlet pipe
Ps disconnect the battery first !!
Chris
Once again, thanks for all advice
I'm trashing the ****** chrome dual regulator tomorrow
And fitting a Malpassi Filter King with a built in gauge.
All the fuel lines are brand new throughout.
I have a fear of touching/removing the carbs/linkage as I don't want
To mess up the tuning I paid for.
Is there an easy way to blow any crap out of the things
Or a way of removing them without affecting linkage etc.....
Ok I've got the Filter King fitted and there's no end of improvement
Drives just fine but maybe a little lean but no popping!
The pressure gauge on the Filter King is at about 2PSI and any tweaking doesn't
Seem to be changing the pressure????
It's running with a Facet Box-style electric pump.....
Any clues on the Malpassi pressure adjustment issue?
I'm guessing it should be running at 3 - 3.5 PSI
Spence
