Garage clearance
rupert the bay
Dec 9, 2007
253
durham
....I need to find my garage floor, so having a bit of a clear out
I`ll be adding more as I trip over it, keep checking
all located in County durham, can post items ...or bring along to viccy farm / stanford hall - payment upfront :albino:
fan shroud, with doghouse , No heater outs, rub down and paint to make nice
£40
no heatriser, no heat back tin - rub down and paint to make nice
**SOLD**
34pct carb genune solex , on manifold , with ends, looks in good condition, but I couldnt get the bugger to idle smooth when I fitted it, so could probably do with a rebuild
£100 ??
twin 40 Dellorto DRLA`s, with manifold and hexbar (including little springs) - but NO airfilter bases (which support the hexbar)
condition is good - I`d recomend a rebuild for total peace of mind, but just removed from my bus after many years good service, one of the balance tubs things is snapped off and some gunky aruldite squished in too ensure no air leakage (see last pic) apart from this, everything turns, ops, shuts, as they should
34 chokes
**sold**
genuine Harrison awning
decent condition, except for an area in the roof the mice have eaten over the winter :roll: :roll:
pics pre mouse action...will take pics of chewage if anyones intrested in it
£100
36hp style fanshroud with doghouse & heater outlets, new and freshly powbercoated black
**sold**
Devon table
66-67 spaceway i think
blue vir-var formica with alloy edge...bottom is missing the thin ply and no fittings
£50
Pop out with great solid frame , but cracked glass....will include not so great one but with good glass
£25
x2 alloy pop outs with good glass and perished rubbers - will polish up
**SOLD**
LHD steering box
£75
Devon easico 12v light....has a little bit smashed, but placed on the top, hard to see when fitted
£40
splitty fuel tank, scabby paint but solid, no leaks, clean up well with wire brush and paint - sender may work, may not, I never really tried too hard to get it working
**SOLD**
electrolux fridge...needs a couple wires fixing....may work, may not....but should
£10
14" bus wheel with whitewall band tyre ...loads of tread
**SOLD**
fold down rear seat from a fleetline splitty...might work in a T4 ...or anything...or your garage as a nice seat ;-)
**SOLD**
splitty beam - rusty, but solid apart from 2 holes on the towers....repair, rub down and paint...or use to make your own with new endplates etc etc
£30
Rare westy rear cupboards
£80 the pair
fisheye indicator backing plates - nice
£7.50 pair
Raliegh Burner blue BMX seat
£10
front deluxe trim - OG
£15
Monroe air shocks...nice and short from about 9 1/2 " - 14"
Cant say i ever had any success in ever lifting the front of my bus with these, about an inch max...but they certainly improve the handling if you set the air pressure to the firmness you desire ;-)
£50
shiny gear knob from a SCAT gearlever
£7.50
oil plate with feed
£7
Electric fuel pump with regulator gives a steady 3-3.5psi...bit tempramental when fitted but i never had a relay fitted, spins fine when I stick a 12v supply on it...no leaks
£20
weird bumper step
£7.50
Steering box gaurd
£10
Rascal steering rack - feels a little notchy when turned by hand
£20
Bay steering column
£10
T25 bevel box - no play
£30
Beetle 4 stud rear drums...good (adaptors removed)
£20 the pair
Bay window disc spindles 71-72...look grotty, but all good, threads good etc....
£25 pair
Firestone airbags - bit rough , hole for air supply need re-tapping on 1 of them, have nicks and wear marks, but hold air well
£20 pair
open to reasonable offers on it all...some more reasonable than others ;-)
