LDM68
Active member
We are thinking of changing / upgrading the gearstick on the '72 bay any recommendations?
dubselector said:Unfortunately you do have to pull the engine and lower the gearbox down to pull the rear shift rod out to access the "shuttlecock" type bushes- but it's well worth it.
dubselector said:I have belly pans so had to pull rod from rear as no access to middle underfloor.
Agreed, with a gear stick extension using some red loctite and some black paintClem said:dubselector said:Unfortunately you do have to pull the engine and lower the gearbox down to pull the rear shift rod out to access the "shuttlecock" type bushes- but it's well worth it.
The shuttlecock bush is split so it’s fittable in situ.
Good bushes and coupler, and an £8 quick shift kit make a decent set up![]()
Is it? I thought they were welded... mine is welded at least on the sides, I didn't realise there might be bolts for the centre piece. Will take a look when I can get underneath it. This would make so many things so much easierClem said:Isn’t the centre section ’bolt on’ ?
dubselector said:There's been more names on the v5 than members of So Solid Crew !
Clem said:dubselector said:I have belly pans so had to pull rod from rear as no access to middle underfloor.
dubselector said:Wow, the ****'s hit the pan ! Nothing like a good worm-can opening exercise to wake every one upOff now to kick a Hornet's nest
Clem said:
lemur said:Clem said:
Nice one Clem, that would hold truck with my experience![]()
L
