got holes in my floor
shiplee123
Nov 30, 2012
1,763
8
East anglia
Not as bad as it sounds. In fact my bus is as solid as they come. It has two or three drilled holes in the floor they almost look like they came from the factory like it. Is this normal . Only small , prob bit smaller than five p piece and one or two bit smaller. What would they b for. If they were drilled after they left the factory what should i do about them. Seal them up / get them welded up ?
Where exactly are the holes?, seat belt mounts are on the kick up panel that goes over the tank, other holes in the floee could be for seat mounts but only if it was a microbus. Pictures always help.
My Westy has those small holes but they have rubber bungs in.... The other large one looks a bit to far back for the seatbelt anchor bolts (in the middle of the floor ) but the hole is a bit big like ? Just get some gromits and find one the right size.
Fit and Forget :mrgreen:
The two holes together next to the wheel arch , the other wheel arch has the same holes in the same place and has clear mastic type stuff pumped in. Why would these holes b there and repeated both sides ?
the 2 near the rear wheel arch are factory and should have rubber gromits,the other one at rear has prob been drilled to hold something down and the small ones at front would be in a good spot for geting some wax oil in to the inner sections of the sill :mrgreen:
