warmed engine no problem, cold idle in current conditions when the tickover is very slow can feel the pulse through the pedal, and if the engine stalls the servo is gone in seconds. does have non return valve fitted, but only have one barrel tapped for vacuum. The nrv looks like a one way discourager rather than a actual valve, can see right through the middle, so guess its bound to decay at some rate, but how fast should it be? wondering about servo corrosion and leaks and how to tell the difference. Are there nrv with a moving part that actually seals when the pressure reverses?
