pgtips
- Joined
- Oct 20, 2009
- Messages
- 85
- Reaction score
- 72
- Location
- Essex
- Year of Your Van(s)
- After 1972
- Van Type
- Westy
I've been intrigued by Lithium leisure batteries for a while now, not something new but not something I really knew much about.
its over a couple of posts as there is a limit to how much text can go in one post.
This is just about replacing a lead Acid / AGM leisure battery with a Lithium one and the steps involved in building one for yourself, save a ton of money too. Its not a recommendation or anything, just what I've done and sharing the experiences I've had.
Why did I want to do this, build a lithium battery ? I was having problems with my old lead acid leisure battery on roadtrips, after a few days the 'fade' of lead acid (like a torch getting dimmer) was giving me problems, getting my heater started was driving me mad, my heater needs a load of energy to start up then happily runs with a lower draw. Anything less than a tip top LB wasn't cutting it, it wasn't much fun up in the Pennines knowing you're sitting in a van with a great heater but due to fade the bloody thing wouldn't start up.
Its the discharge curve that attracted me to lithium. They don't fade, just full whack for (touted as 80% but realistically I'd say 65%) of their power then they go to sleep.
Discharge-curve.jpg![Discharge-curve.jpg Discharge-curve.jpg](https://cdn.imagearchive.com/earlybay/data/attachments/10/10338-ca1034fc733ee66e58d39d0c492625ea.jpg)
Lithium-ion and Life Phosphate (LifePo4) give everything for 'up to' 80% of the time vs lead acid battery is dying pretty much over 40% and fades. Simply wasn't giving me the volts I needed to get the heater on.
So I decided to find out more to build a Leisure battery from scratch. This post lays it out if anyone else wanted to have a go. I can also hold my own now and want to get rid of some false information which bamboozled me at the start.
Got to say a big thanks to Geoff (77 Westy) for giving me answers and explaining a lot of this as I was fumbling around in the dark.
So Lithium batteries, a fact of life now and will probably replace lead acid/agm batteries as leisure ones but they can be hellishly expensive. Building one.. its like riding a bike, difficult until you've actually done it, then you could do it without too much thought.
So a couple of rumours to dispel.
"You can't mix lead acid and lithium batteries in your van"
Well no, not as far as physically joining them together you can't but as far as 2 different types in your bus, lead acid starter and a lithium leisure battery, absolutely fine, no problem at all. Because you never actually connect the batteries together, you go through something called a DC to DC charger.
So as that's the first thing I have mentioned I'll explain a DC to DC charger. Also known as a battery to battery charger. A loose cousin of a split charge but its very different. What you are doing is connecting the batteries together via a special DC to DC charger, also called a battery to battery charger.
It is NOT split charge. You can reuse the wiring but the lithium battery does not connect to the alternator and there's no relay.
What happens is you connect both batteries (which run DC current not like AC in your house hence DC to DC) into the DC to DC charger.
IMG_20230317_101552.jpg This is mine in the side pod under the armrest.
![IMG_20230317_101552.jpg IMG_20230317_101552.jpg](https://cdn.imagearchive.com/earlybay/data/attachments/10/10339-f4921a3f164010119212493b8454dfd5.jpg)
Your alternator (white wire above) provides a trigger to tell the charger to start working when engine running. Similar to split charge once your starter battery is full then the Leisure Battery (LB), via the DC to DC charger, draws its charge from the starter battery (all controlled carefully by the DC to DC charger) and the DC charger keeps your batteries happy. Your starter and LB never actually physically connect.
Charging. Who remembers Gunson chargers !. I had one and had to undo the top of my batteries to stop them exploding. The old method was to leave your charger on overnight/ 12+ hrs connected to your battery. They put out 2 amps, maybe 5 if its a special one. Modern chargers you can just leave, trickle ones.
Lithium batteries charge using a different rating, its called a C rating and it blew my mind a bit to be honest.
The battery which I'll go though in a bit has a C rating of 1 (one). It is really important to know what your C rating is as you don't want to over cook it. What does that C rating mean?. Lithium has really low internal resistance, almost none, so if you have a 100ah battery with a C rating of one it means you can charge at 100amps and in 1 hour the 100ah battery will be fully charged. Your old 2 amp or 5 amp charger is not much good.
So in 1 hour you could charge your leisure battery full from empty if you had a 100amp charger.
But the reality is you won't as they are expensive, I bought a 36 amp one so in theory I could charge my lithium LB to full in about 2.5 hours.
The DC to DC charger also happens to be 40 amps so if I drive for an hour I put 40 amps back into my LB.
I haven't run long enough to know if this is true but on paper that's what it does.
Lithium batteries can also take more charging cycles, they are marketed in terms of number of cycles in the 1000's whereas AGM or lead acid is in the low hundreds so again in theory my lithium battery will last 10 times longer at least. So Halfords new battery, good for say 300 charges, lithium in the 5000 ball park !
But as I said the thing I really liked about lithium was the discharge graph.
Lead acid when it goes a bit weak fades. You can't take a lead acid battery much below 50% before it starts to damage it but a Lithium battery delivers full whack for 80% of the time then falls off a cliff. But you have a things called a battery management system that protects it so you won't damage it.
Weight, lithium batteries are light, I'd guess about 1/4 of the weight for the same capacity lead acid battery and at least half the size.
IMG_20230317_101602~2.jpg106.9 KB
IMG_20230317_082446.jpg157.2 KB
Screenshot_2023-03-12-11-23-16-316_com.inuker.bluetooth.daliy.jpg123.9 KB
IMG_20230317_101552.jpg220.7 KB
130390-5593d92a056696323bbe618ec163859b.jpg3 KB
IMG_20230313_142629.jpg240.6 KB
lithium layout.jpg271.3 KB
IMG_20230312_111638.jpg270.9 KB
IMG_20230312_150925.jpg214.5 KB
connect batteries.jpg15.2 KB
IMG_20230311_172721.jpg202.3 KB
IMG_20230311_121719.jpg180.7 KB
IMG_20230326_190936.jpg283 KB
