cunning plan
- Joined
- Jul 15, 2008
- Messages
- 2,625
- Reaction score
- 1
- Location
- Northamptonshire
- Year of Your Van(s)
- 1968
- Van Type
- Clipper / Microbus
Clarkson46 said:I've got lots of ideas, but with nothing to go on they are meaningless. What carb is it, distributor type, engine spec etc. Are tappets set correctly, does the choke work? What is the timing set to? Is the carb set up properly on a hot engine.
Hoosier said:2 things ive seen in the past. 1 fine slither of rubber (from fuel pipe)sitting on top of the needle valve blocking fuel to the float chamber. 2 wrong wire going to the fuel cut off switch in the side of the carb(needs to be a constant live,not a pulsing one as a result of taking live to the switch from wrong side of the coil).Would rev up but wouldnt idle below 1200rpmdid that one myself
cunning plan said:Choke seems to work, when cold it and you push open the throttle it clicks the stepped choke to one of the taller teeth, run it for like 20-30 seconds and the choke does seem to go in quick..
Johnny said:the flame thrower is nice but your just buying a "better looking" standard dizzy with the electronics, if your dizzy is in good condition just buy the pertronix internals which are almost the same, and save your self money. the flame thrower is also bulkier and might not fit with some applications, i remember kombiporsche had to send his back as it wouldnt fit with in his 1776.
If money isnt an object id get the http://www.123ignition.nl, its not much more than the pertronix and looks a much better dizzy, built in static timing LED, 16 preset curves variable dwell etc.. check out the YOUtube video on the site, very interesting
Johnny said:cunning plan said:Choke seems to work, when cold it and you push open the throttle it clicks the stepped choke to one of the taller teeth, run it for like 20-30 seconds and the choke does seem to go in quick..
your choke shouldnt go in that quick from cold? have you taken the airfliter off and looked at the position of the butterfly valve to make sure its open? is your engine getting enough time to warm up before it starts to cut out at idle?
can you take a look at the choke element? is it damaged? is the spring return damaged?
cunning plan said:MmmMmm interesting... How much are they? Where are they sold in England I cant find a reseller...
A5H said:cunning plan said:MmmMmm interesting... How much are they? Where are they sold in England I cant find a reseller...
http://www.sciperformance.co.uk/onlineshopproducts_53353_49227.html" onclick="window.open(this.href);return false;
Clarkson46 said:This is just my opinion, but ditch the airfilter and return to stock, loose the dissy and again return to stock. Adjust your tappets. Invest in a timing light so you know that the dynamic timing is correct. Read this site.
http://www.vw-resource.com/34pict3.html" onclick="window.open(this.href);return false;
cyberdyne systems said:The carb (34pict3) is notoriously difficult to use with anything but the correct 034 distributor. Common symptoms are poor idle and flat spots on acceleration.
Having said that it should still be possible to get it to work better than what you describe.
First thing I would do is go through the carb set up, make sure you adjust the 34 carb properly, there are two adjusting screws on the side - bypass (idle) and mixture. Make sure you didnt try and adjust idle from the throttle spindle set screw (the one that goes on the fast idle cam). Once you have a basic set up, then statically time the engine and start it and maybe drive it to fully warm it up. Then you can do a proper time with a light and then set the carb properly when the engine is warm. You have to set an 009 distributor at its maximum advance (aprox. 28 - 30 degree's) not at idle.
It could be that you have a bad choke coupled with some tune up issue's. The advice to go back to stock is also sound. The stock aircleaner will have a pre heat for the manifold as you problem might be icing up of the manifold just below the carb (check it when it stalls), also make sure the heat risers are connected and warming up too.
Hope this helps
Gareth
