robins said:....and if you think about it putting the insulation on the metal panel and leaving a gap door card side :roll: all your doing is as above creating more condensation on the metal,put the insulation in so it doesn't touch the out side the you got no condensation probs
Moseley said:robins said:....and if you think about it putting the insulation on the metal panel and leaving a gap door card side :roll: all your doing is as above creating more condensation on the metal,put the insulation in so it doesn't touch the out side the you got no condensation probs
I'd say the opposite. The point of dynamat style insulation is that you want to stop the moist air inside the van from coming into contact with the coldest parts of the van, i.e. the external metal skin. Adding further insulation in the form of sheeps wool, closed cell foam etc etc further helps to stop the air inside from circulating close to the outer skin of the van. Obviously the downside to having all the insulation in situ is that any moisture that does find its way into it or behind it will be harder to remove and can pool over time.... Insert rust warning here!
robins said:Moseley said:robins said:....and if you think about it putting the insulation on the metal panel and leaving a gap door card side :roll: all your doing is as above creating more condensation on the metal,put the insulation in so it doesn't touch the out side the you got no condensation probs
I was talking about the insulation,dynamat is a sound deadening products I thought that was stuck to the panels :?: like flash band I think some have used
gas1man said:Flashband all over and no insulation
J & P
sparkywig said:gas1man said:Flashband all over and no insulation
J & P
You only need a square in the centre of a panel for sounddeadening. If you cover the panel with it, it can still trap water unless it's heated and rollered down when applied. Even then it may lift if the panel's not perfectly clean.
I've had this issue with my squareback and dynamat. It's trapped moisture and started to rot the floorpan.
