Added final wraps of thermawrap insulation to the heater tube at the front of the van, before refitting the belly pan.
Added some flash tape in flat areas - I don't want to put any in the front cab on the inside. I'm actually going to paint over these bits, just to hide them a bit and maybe hel seal them on - no big deal if the paint does crack after movement, as the paint under them is good, but actually I doubt there will be any cracking anyway. Little patches are just covering the odd hole. I have sprayed dinitrol into any box sections.
Have started to add a different layer of foam on the inside, before laying thermawarp on the floor, more foam (very thin) then - I expect - a ply floor, and for now re-attach my side panels. I might use them as a template and make some more if required.
![086.jpg](https://proxy.imagearchive.com/bdd/bdd05d2bc586c7ddba4b65fe5ec3c11b.jpg)
![087.jpg](https://proxy.imagearchive.com/771/77194050264d7c490b5fb40645b1627d.jpg)
