TransporterHaus
Fitting a narrowed beam to your bay? We have dropped spindles in stock ready to go.
64-67 split bus dropped spindles £243.75 exchange (July only - usually £325). Drum or CSP disc brakes.
64-67 Disc dropped spindles £281.25 exchange (July only - usually £375). 73-79 VW disc brakes.
Fully rebuilt with new genuine VW seals, 4 new bronze bushes, new german grease nipples. Machined to give 3.5" of drop and far better ride quality than a balljoint bus + they will last longer than balljoints if you go really low!
These will not fit onto your stock bay front beam. You will need to fit either a 64-67 split bus front beam or a CB performance narrow beam and use 64-67 split bus trailing arms. These beams will bolt straight onto the very early bays and will fit later models with a little modification.
Email [email protected]
Web http://www.transporterhaus.com
