Hi all. I have a '69 Bay that I have stripped down. I have identified areas that need welding. I am competent on most stuff apart from welding and want to know if this work below will be too ambitious for my first batch of welding! Perhaps I should get a professional to weld these and then look into learning to weld in the future. Any pointers to repair panels for various bits would be very helpful!
Underneath is solid as is the rest of the van.
Tailgate - The inner skin has come away from the outer just at the base of the window all the way across. May be cheaper just to buy a rot free one.
Gutter - Needs attention at the back and on the near side about 50% of it.
Inner wheel arch. Rotted where seatbelt mount goes. Poor previous repair
Sliding door panel (underneath the rear quarter window). Looks worse than it is, but there is a hole on the window frame
Battery tray - Might be ok
Back NS panel underneath the window - Rotted to hell!
Boot floor above engine - Hole
Spare wheel well - Hole, could hopefully just be welded over.
