Dirty Harry said:Watch it with the BBT repro ones, they are total crap!!!!!
The rubber seal is so thin that it deformes and shrink to 50% of it's original size after got wet from the gasoline they are a total waste of money :evil:
Or you can put a lock on the flap instead.
Delilahtoo said:Trikky2 wroteOr you can put a lock on the flap instead.
Good point, thanks. Any advice on how to go about this as an alternative to an actual locking cap?
Trikky2 said:Delilahtoo said:Trikky2 wroteOr you can put a lock on the flap instead.
Yes. You can buy simple filing cabinet type locks from iron mongers.
You measure for the correct position (so the locking tab locates when locked without the lock itself catching on the body) and drill the flap and fit.
Most come with a tongue which you can bend for a better closed position or you can make one from a small off cut of 1 to 2 mm sheet.
lcfmonkey said:I have a snapped off key in mine! Is it buggered or can I get the barrel replaced? If so, by whom?
Chars!
i was about to say iv got a locking cap but no key... hoping for suggestionssparkywig said:lcfmonkey said:I have a snapped off key in mine! Is it buggered or can I get the barrel replaced? If so, by whom?
Chars!
Find a local locksmith and he'll be able to remove the key and cut a new one from the lock.
