Manifold heater question
martyboy
Nov 8, 2008
162
ipswich
Hi I just wondered if anybody has got around fitting a IMDU Manifold Heater to their bus with the large servo pipe on the manifold in the way. Thanks
never had the need for one to be honest. I thought it was more of a cold climate accessory. I've never experienced icing before and i'm out 12 months of the year.
id a quick google and this one clearly has a servo pipe tee'd off the manifold...
Don't the heat riser pipes from the exhaust prevent icing? along with the hot air feed via the air filter from below the engine tin?
Johnny that's the set up I have on my beetle which on a cold morning runs a treat ,doesn't cut out at junctions
My bay manifold has the small as per your photo and also a larger pipe which runs up the van to the servo I think
Larger outlet makes it impossible to fit the jacket.
