buddysbuddy
Population of Early Bay, I call on your experience and knowledge to hopfully help me out!!!!
As part of the work I was doing under the bus I decided to overhaul the brakes - sticking with standard but replacing all parts. This included a new master cylinder. The first problem to over come was the issue of 2 outlets on the new cylinder vs 3 on the OG. Easily resolved with a Tpiece and some brake pipe.
The issue I have is with the lower reseviour, in my haste I ordered a new one along with the MC from Machine 7 upon receipt it was clear that the 2 are not compatible......in fact it appears that there is no reseviour available that will fit on a 69 MC!
I then decided I would just use the OG res of my knackered MC, however, as I tried to remove it just crumbled in my hand!
So the problem I have is no reseviour and no idea what to do next?
Any ideas, where I could get an OG reseviour from? Is there any way of getting around this?
Help, this is now the only thing getting in the way of using the van!
