jacks906
hi all
having some breaking issues and have decided to change the lot
so both new front + rear kits ready to be ordered
just trying to figure out what M/C i need :?
my bus is a 1970 with wide 5 drums all round
now the reason for changing everything is
A. the pedal is needed to be double pumped to get a good pedal for braking (i know it sounds like air in the pipes but can garentee there is none.. i think.. read on)
B. when bleeding the brakes no matter which way i try once the backs are bleed up the pedal wont fully depress to bleed the fronts up (this has only come on recently an has never happened before, when changing beam,wheel bearings etc)
so i cant decide if im suppose to have this one
http://www.vwheritage.com/vw_spares_Master-cylinder-LHD-RHD-T2-1970-only-No-Servo_act_shop.product_pID_145152_lang_EN_country_GB.htm?crumbPageToLoad=1" onclick="window.open(this.href);return false;
or this one which is what i think i currently have
http://www.vwheritage.com/vw_spares_Master-cylinder-LHD-RHD-T2-8-70-79-No-Servo_act_shop.product_pID_135929_lang_EN_country_GB.htm?crumbPageToLoad=1" onclick="window.open(this.href);return false;
they look slightly different but im not sure what the acutual performance difference or pros n cons to each one are nor do i know which is the one i need
cheers for any help
dave
cheers for any help
dave
