I am in the process of repairing a stud on the sump/case,annoying little weep so i've took the bull by the horns and am trying to replace a bolt with a new stud.
On to my question,when you do a full oil change and not an intermediate(running engine in)and you replace both gaskets(one on the face of the case,the other on sump plate)do any of you use Gasket Sealant on either side of the gaskets or just leave alone and use the gaskets on their own??
I did not want to tweek the nuts
too tight like the PO of the case and damage/strip the threads on the studs using a 10 mm spanner and end up with another useless case.
Fed up with having to leave a tray on the garage floor or do VW engines leak slightly,i'm guessing not.I've seen relatively new Transit's and the like dripping on the floor so i suppose not everything will be perfect.
Am i asking too much of the sump plate and engine??
Standard 16tp with oil bath filter and 34 pict 3 carb so totally standard.
Regards.
Sharky.
Regards.
Sharky.
