Brand new 25PSI is fine, its a little high but OK
Your engine being fresh everything is tighter and oil pressure will be a little higher!
What Oil are you using?
This time of year when you start your motor with cold oil I'd expect you to see 25PSI minimum
Performance motors can run 70PSI plus so high pressure is nothing to be afraid of.
Better pressure is a good thing!
10PSI is the minimum you'd ever want the oil pressure light comes on 4 - 6PSI and if it drops this low and the light comes on its normally too late!
I generally ran at 25PSI at tickover and upto 65PSI at 6000RPM on my 2276cc, Cant tell you for the 1776cc as I never ran a gauge.
Its just another worry gauge, see what is normal for YOUR van and only be concerned when its doing something it does not normally do.
Hope that helps :mrgreen:
