- Joined
- Nov 28, 2012
- Messages
- 926
- Reaction score
- 52
- Location
- Herne Bay, Kent
- Year of Your Van(s)
- 1970
- Van Type
- Devon
I've been pretty busy on the bus the last couple of weeks. Maybe it's because I am fed-up of everyone asking how long it will be till it's on the road!!! :lol: OR maybe it's also that the end is in sight. People reassure me that the putting back together is the fun part!
Heater pipe all done, well I say all done it's welded in. Still needs sealing, painting etc. It was really hard to get the right angle as the original is bent slightly. Hopefully the flexibility of the of heater tubes will compensate for it not being spot on.
The heater panel thing is all done, sealed up and etch primed.
Next up was to attack where the engine seals go. The bit over the gearbox needed sorting and also the bit down the side
So I cut stuff out.
Put a new plate in and will make the cuts when I am confident it's in the right place.
No I did do the bit down the side and it's all clamped up but seems to be an issue with Dropbox and the photos haven't uploaded.
I got a bit stuck last night as the bit I've welded in over the gear box was sitting at an angle. From top to bottom it started to bend towards the front. Now I don't know if it's supposed to be angled or it is supposed to sit flat. I tried to get an idea from the other side but I couldn't get anything in there to work out if it's a right angle or not.
So my question is, the face of the bit that sits over the gearbox, is that flat? As I am worried that if I stick it all where I think it should go, the engine tin might not fit? Or it might not be sealed up properly. The only way I can think to be sure is to put the engine back in and I don't really fancy doing that!
So I cut stuff out.
