After Norton Scan and AVG scan nothing found, maybe it's photobucket? :?
Oh well, I shall continue.
I started working on removing the firewall and taking a look at the fuel tank. Pretty worried here, as far as I know it hasn't been looked at since 69/70. Screws were all pretty knackered but got it off.
Tank out
Good news! The tank seems to be in top condition. I will still treat it as it's out and inside was a bit of relief! Only one small section that had rotten through, weird how one side rotted but the other is spotless?
This it a little rotten as well and will need patching up. Also the channel the seal sits in needs fixing. I noticed on Autocraft they sell this channel but it's to 67 only. Going to give them a call tomorrow to see the differences.
In between I had to work and out getting some fresh air I saw this driving past. Not sure what it is but it was MASSIVE...but was truly stunning. Worked there for 8 years nearly and never seen this at the station before, hope to see it again! Wished I'd stopped him and had a proper look.
After that fun I had a new tailgate arrive from Sussex Kampers as the mine was bashed and bent back into shape and filled over (no surprises there then...), and I got 25% off for Christmas
It's a beautiful colour as well, shame I will we covering it up.
Some may notice that the top right corner has a tight gap to the corner (more on that in a sec). The valance I bought on EBay (as mine was surprisingly all bent and buckled), is straight but it has some rotten bits underneath (so I'll be selling it on to a Rat bus owner hopefully) and getting a new one.
This is where the tailgate gap comes in. When we reset the corner we did so with my bent and buckled tailgate, so when we stuck the nice straight one in we realised what we missed. So after doing that corner twice now we have come up with a plan for the third and final time! What we are going to do (with the tailgate in place), is cut under the swage line and lift the top of the corner up a couple of milimetre's and then reweld it. That will get the top nice and straight again. As well as doing this, I need to get a new hinge repair panel, new valance and new tailgate. Offer it all up and weld it up! Hopefully I will be able to source all of that tomorrow for delivery on Friday and that is the the task for Saturday.
In the meantime, once Ronnie decided he was wasting time trying to repair that section with the bits we had, he went back to filling and flattening down.
Some pictures of where it's up to now.
We were hoping the door would get done as well, then some of the front so we can turn the bus around and do the other side but the frame in the door needed sealing up as the outer panel was rather flexible! So we had to stop there. The rear corner will need doing again once the rear end is finally sorted out. But from the rear wheel arch to the front is all done
That was the hardest part because of the C Post being out of shape, Ronnie has done a stunning job so far and we are really really chuffed! Hopefully the near side will be a lot easier as it should structurally be in the correct position!
I've been attacking the hole in the fuel tank area which is now welded up and sealed - didn't take any pictures for some reason. I had to re-make the strenghener bit and I was rather happy with how it turned out!
Then I turned my hand to the hole where the rear heater vents come up.
One of the pipes litterally fell off when I touched it, the other is mostly solid accept for a small hole. The reason for doing all this is that we don't want the rear heating vents. So I am going to close it up so the heat goes to the front. Mainly for storage reasons, with the vents there, and then needing to be encased we are losing a lot of room under the seat. So as it's mainly going to be us two heat up the front is fine.
There is a lip that is on the reverse side (in the engine bay area) where the floor and the panel I am replacing is welded. I guess for strength. Well that is non-existent. Rotted away many years a go no doubt. So I've had to tack a lip back on the inside which I will tap down to make the lip on in the engine bay. The panel that I have to replace this one is also rotten along that bit as well, so I've cut it off. My plan is to weld the lip back on the replacement panel then tack it to the lip on the bus. Then as I bend over the replacement panel in to place it should bend the lips where I need them to go as it will be impossible to weld from inside the engine bay. If it needs straightening out then hopefully that should be easy. Then weld the panel in place.
That is my plan today so fingers crossed for me!
