paint
shiplee123
Nov 30, 2012
1,763
8
East anglia
Hi the inside of my van will b receiving a full refit over the next year or so. Im just trying to get things sorted in my mind. One of many questions is about matching the correct paint colour. My bus has had a full respray and the chap said it was the original blue. This colour code was taken from the label behind the front seat. Can i match this colour where can i punches it and does it come in spray cans ???
This would b to recoat any scratched panels etc inside
The metal VIN code plate will have the paint code on it and there also should be a sticker with the paint code too.
Confusingly, they use different code abbreviations for the same paint :roll:
The paint code stickers are fairly easy to translate (it spells the name out too) but the VIN plate is a bit harder:
http://www.type2.com/m-codes/t2colors.html" onclick="window.open(this.href);return false;
The paint won't be off the shelf any more but any decent local paint shop should be able to mix you some up or even put it in aerosols if that's what you need 8)
Write your reply...
