smudge
Any about or info on where to get some from?
Smudge
Smudge
Hi Tim..As in 'You do' or 'I can'?Monkeyspinner Tim said:i buy new ones from GSF and cut one end down to the desired length...
smudge said:Hi Tim..As in 'You do' or 'I can'?Monkeyspinner Tim said:i buy new ones from GSF and cut one end down to the desired length...
If you mean 'you do' then will you be good enough to give me a price?
Cheers Dude
Smudge
smudge said:Thanks dude.I did just get the Single cab my friend yes.Funny enough before i got the S/c i was looking at the s/biege bus that you now have .That would look sweet slammed dude :wink:
smudge said:Just regestered thanks Tim
Your Bus mate...are you running an adjustable split beam on dropped spindles?..Liking the stance.
Ill be running a set of 4.5j SA Sprinters on the front...not sure of the offsets.
Agreed with you on the 6" narrow beam..to narrow for my liking!
So if a split beam is 60mm longer from standard.....what sort of efect do you think i would get from chopping the beam from the wheel side of the towers(between arms and tower)As like the Jiffy bus is done im led to believe??
smudge said:the beam that came with my bus is this one
http://www.wagenswest.com/parts.html
thing thats getting me is the years it states it fits...it looks to have 2 different mounting paterns so can understand that....the confusing bit is,is it ball joint meaning you would have to run an earlt split on BJ's or would it take KnL ?
Bloody ell think ill sell the beam and buya splity one :lol:
smudge said:Not sure on the month Mate..Vin is 269144854 if you can tell from that?.Other than that is there any other way of finding out from the bus?
