Hi
I'm looking to put a full length ply headliner in my van.
I only have a cab headliner at present, but thats starting to come adrfit - I think its the damp....bugger, thats also helping the rust. Theres no evidence of a headliner of any sort in the rear - no brackets, no holes nothing! :?
Looking at the various forum threads it looks like 3mm ply, finished with yacht varnish is the thing to do. Then theres the fitting. It looks as though you need 'j' brackets that run down the side of the roof. Schofields are mentioned as a supplier.
How high do you mount the brackets?
What do people use to join the sections used to make the headliner?
Is anything used across the front and rear or is it just the sides? If not how do you finish off the front and rear?
Does anyone out there have measurements for the panels?
As usual close up photos (original ply roofliners would be good to see, warts and all as well as replaced items) - particularly interested in the front and rear areas so I can see what I need to do.
Thanks, Nigel
Thanks, Nigel
