AGC
Engine (1600tp standard) has been starting first time by depressing the accelerator pedal to the floor and releasing it slowly to engage the choke then turning the key. This is from cold by the way. This is the method VW recommend. Now however it wont start easily by using this method. could it be that the plugs need cleaning/changing. Its recently had new leads, points and distributor and the battery seems strong. Any advice gratefully received. Also has "overrun" a few times when switching off.
