Bigbear
I'm after a bit of advice from anyone who has fitted a disc conversion kit from csp.
Firstly, the master cylinder on my bus doesn't have the bearing to remove so I ordered the two fittings that screw into the master cylinder, however, these do not fit!
Secondly, after fitting the first disc I noticed that it catches the bottom of the spindle with the inside edge of the disc, can I shim the whole thing out a few mm to miss the edge or shall i just shave a few mm off the bottom arm of the spindle with a grinder?
Starting to wish I'd never ordered this kit!!
