Just changed the headlights to UK spec and done the front indicators, all lights work apart from high beam, any ideas on what to look for, the Bentley manual suggests the high beam relay that is connected to the back of the fuse box? if its this is it an easy part to replace.
Question on the reverse lights, there are 2 wires to the gearbox, one goes to the lights but the other is cut off just inside the engine bay, i believe this should be the power cable as i found an inline fuse holder in the box of bits that came with the van with the same colour and guage wire and i have seen pictures of engine bays where this fuse holder is clamped onto the tinware next to the coil. not sure why its been cutoff, does this connect direct to the positive (via fuse) of the battery?
