5erge
Let you guess the name of this thread.
Hit my first snag fitting the wishbone kit, it's not a biggie but I just need to relocate my front brake line and brake line bracket where it meets the brake pipe. It currently fouls the wishbone sideplate. Please note: this is already highlighted in the fitting instructions.
Looks like the bracket is spot welded to the chassis, so I have started to drill out the 4 spots on each bracket, not sure if I can use the brackets afterwards but I will get some more made up, or just make my own, can't be that difficult.
Has anyone removed these brackets before and should I be using anything more heavy duty to remove the bracket? Its just I've gone through one drill bit already :roll:
Des
Des
