wil
Active member
Hi all,
What engines are you guys running in your early bays? I have the choice between getting a SP & TP engine rebuilt.
My van is a tin top & will needs to carry x2 adults & a 1 year old (+ all the stuff that comes with him) so not too heavy a bus. I want to be able to cruise at 65-70mph on long journeys & not have to tinker with the engine other than servicing.
A little bit of background, the TP has twin dells on it (36DRLA) & was great when it was running but there always seemed to be a problem with the carbs + it was a real sod to start up from cold. A burnt valve meant this engine was put out of service.
The SP that replaced it had slight end float but ran great (sat at 70 for 200 mile plus without any struggle/strain) + it started first time every time.
After searching around on here it seems a lot of you run SP engines & i'm inclined to go down this route, using the oil cooler, doghouse & fan from the TP.
I don't have a budget in mind but wouldn't want to venture over the 2k mark if possible... Any suggestions or have any of you been in a similar situation?
Thanks in advance
Thanks in advance
