Hi sorry if it's not called rear brake pressure regulator but it's positioned behind the master cylinder on my 72 earlybay basically I think it's goosed it supplys brake fluid to rear wheels and it is allowing fluid to go in but not out I have removed it stripped it down and cleaned inside there is a large ball bearing and looks like a piston and spring I have put it all back together but still not allowing fluid to flow out was just wondering if I do away with it and put a piece of flexi pipe in its place to allow fluid to flow to rear wheels will it cause any problems or would I be ok to do this I presume it's there so the rear wheels don't brake at same time as front wheels any advice appreciated cheers
