AndyO
G'Day All,
After a bit of advice, after fitting horseshoe plates on the rear of the bus she sits a bit too low, the driveshaft’s are catching on the chassis when even slightly loaded in the rear. Also she sits a bit low compared to the front (drop spindles). Given that I plan to tow and it sits a tad low I figured that adjustable rear coil overs may be just the ticket - it would seem that VW had the same idea:
http://www.justkampers.com/forum2/viewtopic.php?f=15&t=166753&hilit=
Has anyone on here done this, if so where di you score the shock from?
Currently looking at these:
http://www.corbymotorsport.com/1-34-bodies-12mm-rods-bonded-bushes-p-4298.html
19" version, they also do a 2" body with a 14mm rod - guessing that this may be a better idea as they are more substantial, not sure about clearance though...
