hippysteven
- Joined
- Apr 23, 2009
- Messages
- 167
- Reaction score
- 0
I'm onto one of my last jobs now on my (wide 5) bay before MOT day,
The problem I have is the rear brakes are naff. I've replaced the cylinders, shoes and all the other gubins.
I removed a lip around the inside of the drum using a flap disc which come about because the previous shoes had partly worn the drum away as they do. The lip was ruffly 1mm.
I've slightly angled the edge of the new shoes as advised by the MOT guy last year to help them bed in
I've replaced both hand brake cables with gsf cables. I've adjusted and adjusted and with the handbrake firmly on, I can still turn the wheel by hand with abit of effort.
As you probs know csp drums are nearly £400 just for the rear end, so I'm not sure where to go next that's guna improve my brakes, I did consider that the cables could be stretching as I pull hand brake but they're new.
Anyone else had trouble setting up there rear drums?
Any help appreciated because it's the only thing letting my bus down.
