Red 9 EZ Riders, what you running?
Mags
May 22, 2009
519
2
About to bolt up my EZ rider and not a clue what hight to start and then what tyres to run. Trying to look at the different options people run with tyre sizes is making my brain hurt. I'm planning on sticking to my steel 14"s at the moment so this might dictate the tyre choice I guess.
I'm thinking of starting one hole down (4" drop I believe) and slightly smaller diameter tyres if I can find a suitable size. Would like to know what others have done and what tyres you are running.
I've got standard wheel tubs so can't go too extreme and want to keep stock tyre size on the rear to not mess up the cruzing speed.
Mags, have mine on standard wheels 'n' tyres. only went for the 2.5 drop and same with the arse end, though I had to also go down One spline to level it off...
Am off to check progress at the body shop this week so I can get you some photos to look at to get an idea if that helps ?
I have just fitted EZRider kit and I run front 175/65r and on the back 175/80r and there on 14" wheels if you want to see what they look like on try this on my gallery http://forum.earlybay.com/viewtopic.php?f=2&t=36574&start=60" onclick="window.open(this.href);return false;
cheers Shaun
Thanks Shaun, it's the full double wishbone setup that I was referring to, but nice bus all the same! The stance looks good.
I bolted it up on the highest setting in the end, 3" down from stock I think. Not a bad starting point on standard wheels and commercial tyres.
