Hi again. I will be replacing a couple of bits on my new camper (the front grille to start with, together with a new arch etc). The paint job is currently hand painted, so I will be sanding down. After someone has replaced the arch and any other bits, what's the correct sequence for prepairing for paint? Is it just etched primer, then paint? Ideally, I would like the do all the prepping, then pay someone to spray.
I assume I can't put etching primer over top of the paint that I rub down, so do I just use normal primer here?
Is it possible to actually leave the car in primer for a length of time (and drive it about)?
Thanks again.
Thanks again.
