Reprowesty seatbelt bracket
RednWhite
Feb 19, 2011
73
Hi,
I'm looking for feedback on Reprowesty's three point seatbelt bracket fitted to a US spec (LHD) Westy with wardrobe.
Does it need fixing points welded to the floor or is drilling for bolt points sufficient?
Thanks in advance
Hi,
I assume your referring to this?
https://reprowesty.com/product/vw-t2a-montagesteun-3-punts-gordel/
I had been looking into this also but from what I have been told they will not ship to the UK.
With regards to mounting it doesn't specify mounting method. Being as the mounting surface is profiled putting a secondary plate above the fuel tank and bolting though would require spacers to prevent the profile from crushing when tightened. Plus its a ball ache to drop get to the tank area. I suspect that it is mounted using rivnuts, but cannot confirm.
Let me know if you manage to convince them to ship to the UK as I also want one.
Hi, I’m considering these mounts as a solution for rear 3 point belts as well, especially the side next to my westy wardrobe, I know that the other extenders that places like hertitage sell can be made to fit the window side, but these look a neat solution and the reel looks above the cushions.
Has anyone managed to order them from reprowesty??
Hi,
From that picture posted on the website, it's not clear how & where the brackets are mounted (especially near the top shoulder mount), and how robust it would be in a collision!?!
If this bracket is attached to the fuel tank platform only, I wouldn't use it.
There's no way you could make it secure enough in the unfortunate event of an accident. Those bolts would just rip out of that panel.
