junkyardjim
on removal of my single port rocker shafts there does not appear to
be any gasket/seal between the shaft mounting and cylinder head. Is this correct?
I have the remains an engine rebulid gasket set with a few o rings/penny washer sized fiber gaskets left over but do not know the correct type to fit having had none there in the first place!!. The engine has been running
fine for the last 6 years or so with just regular servicing, and there does not appear to ne any wear on the rocker shaft nmounting or head. Any advice/feedback would be appreciated - Thanks.
