P Paulwhite68 Member Joined Sep 6, 2015 Messages 20 Reaction score 0 Apr 24, 2016 #1 Servicing my 1600 twin port.... Direction you put the silver plate between the block alternated stand! Or dose it not really matter
StuF Well-known member Joined Sep 17, 2011 Messages 2,907 Reaction score 3 Location Lincoln Apr 24, 2016 #2 I put mine on this way round - although not sure if its correct! Hasnt leaked though! 8)
rlepecha Well-known member Supporting Member Joined Jun 11, 2013 Messages 636 Reaction score 4 Location Leeds Year of Your Van(s) 1971 Van Type Microbus M-codes 095 508 697 A01 Apr 24, 2016 #3 Same at Stu on my bus, but never fitted a paper gasket as well? Never seen one in the kits?! Its that way around to allow oil to flow back easier I think. It stops oil sitting on the plate. Sent from my Siswoo C55 using Tapatalk
P Paulwhite68 Member Joined Sep 6, 2015 Messages 20 Reaction score 0 Apr 24, 2016 #4 No I didn't have the paper part neither. I thought the same as you but the picture in the manual has it turned 90 degrees! So who's right! Thanks guys
rlepecha Well-known member Supporting Member Joined Jun 11, 2013 Messages 636 Reaction score 4 Location Leeds Year of Your Van(s) 1971 Van Type Microbus M-codes 095 508 697 A01 Apr 24, 2016 #5 Not sure it makes a lot of difference the rotational direction, mine might be the same as the manual.. Can't remember, it went on in the direction which it fit without flattening the 'fins' Sent from my Siswoo C55 using Tapatalk
Trikky2 Well-known member Joined Jan 8, 2007 Messages 3,890 Reaction score 4 Location S.W.France Apr 25, 2016 #6 Fins down with openings to the right. (Makes sense - think about the oil flinging rotating bits).
