Show me your 4" narrowed beams
All welded and one shock tower off which, incidently wasn't that hard. It only took about 10 minutes ;)
Hi
just a little tip I was told when doing mine
I bolted the end plates to the van but put 3 sheets of A4 behind the plate and chassis,
Then mocked/centralised it up and tacked it together
Removed beam and weld up, the sheets of A4 give you clearance when re fitting
Looking Good ;)
And so you should be. It's a **** job! It takes guts to get in & do one yourself. I bought someone else's effort & was tighter than a tight thing to get in.
Looks good so far...
looks all good mate. i tried to do the same thing on my bus but when i cut the ends off the tubes were fooooooked.
i ended up buying a ce beam. heres a few pics
You mean the shock mount on the trailing arm?
I'mm gonna trim the bottom of the plate anyway because I think it will hit the floor. Also don't forget I have the new T2D dropped spindles and reversed balljoints so I don't think it will be an issue, cheers for the heads up though dude and thanks for the earlier compliments :)
Jay, that looks fookin' ace! Makes the sprinstars look even cooler!!!
Do the tyres clear the inner part of the front arch now?
i read this at 6:15 this morning while i was eating my shreddies (sad bastard i know) didn't notice the 2nd page got to the bottom of the first and posted mine. I <3 your work mate, looks really good !!!!!!!!!!
