starbiscuit
Hi all,
I finally figured out why my sliding door won't pull-in by lifting the outer handle.
Firstly, the locking plate on the B post was too high, so the hooked latch wasn't dropping far enough to allow the locking bolt to stick out along the top of it.
Secondly, I noticed that the little plastic lever on the inside front lock keeps drooping to about 8 o'clock, instead of staying horizontal.
Not enough to lock the inner mechanism but enough to prevent the outer mechanism from operating.
As far as I know, I haven't broken anything. So either it's always been like this since I've had it, or it's meant to be like this.
But I would have expected that lever to have some positive location: horizontal 9 o'clock = unlocked, vertical 6 o'clock = locked.
Not all flopping around under gravity.
So, not wanting to buy a new lock, and not wanting to destroy mine trying to get inside it (it's riveted together), has anyone fixed this issue before?
I'm thinking that if I pull the plastic lever off and turn 90 degrees, I could have 12 o'clock = unlocked and 9 o'clock = locked, so it's less likely to droop into that half-locked position.
Does that lever come off without busting it? It seems fairly firmly fixed.
Any other ideas?
Thanks for reading !
Any other ideas?
