Bigbear
Mine are fixed using the same foam as you, they seem to work fine.
I do notice different sound quality depending where I am in the bus though, in the back it's quite bassy as I have fitted an exciter directly above the rear bed,( a larger panel) whereas in the front it's more trebley (excites are fitted on the metal part of the doors which is obviously smaller) just play around with different surfaces until your happy.
Remember to try different settings on your stereo on each area you try aswell.
