froggy
Was looking through the Haynes manual that came with my bay and on the back (inside cover) there is a drawing of the crank pulley with 3 notches (5 deg ATDC, TDC ans 5 deg BTDC) and the valve position.
The diagram clearly states that the engine was set a 5 Deg ATDC (after top dead centre).
Is this right?
I've only ever ran the engine for a few minutes just to keep things turning, and it sounds alright but everything i've read mentions different settings.
The engine is a stock 1600 TP, standard Dizzy with a 34 PICT 3 carb
Is this right?
