i know its not easy to tell from pics but have i put this back together rite as i am sure the colum felt alot tighter if that makes sence allso the horn wireing ,i have run a cable down the cntr of colum shaft and from what i can make out this goes through the cntr of the coupling bush with an eye terminal on and bolts to the steering box (how much slack do you leave as it will turn with the wheel :? ) the terminal in the outer tube broke so i managed to drill the rivet out and pot rivet a terminal to this which goes to the horn i think (ive left cables hanging under bus at the mo till i fit new loom) none of this probaly makes sence but ive put some pics up if you could cast your eye over
