step by step guid to fitting beam adjusters and narrowing
stevewest
New member
Feb 16, 2014
3
im looking to fitting beam adjusters and narrowing my front beam, i found a guide but it doesnt show my beam, mine is 1972 crossover and has a mount near the middle of the beam so not sure wher to pu the adjuster? or how to narrow as this mount is in the way of cutting the middle out? :?:
You cut the steering idler mount off, drill the dimple out and re-fit the mount.
King and linkpin beam, but the same adjusters.
If you're planning to fit dropped spindles at some point, you'll need to fit the adjuster further around the beam otherwise you won't be able to raise the adjusters enough.
