_666_
- Joined
- Aug 14, 2022
- Messages
- 13
- Reaction score
- 4
- Location
- Australia
- Year of Your Van(s)
- 1968
- Van Type
- None
Hi all, in the coming days i will be installing a tandem brake booster into my 68 Lowlight Kombi
i have a few questions about the install, am i right in saying i need to make up the following pipes
1x pipe from the tandem brake master (front most port) to the rear of the tandem brake booster (the side with the black bit) (3/8"-24 male to male fittings)
1x pipe from the rear of the Master to the front of the booster (3/8"-24 male to male fittings)
1x pipe from booster to a T connector to split into the front brakes.. (are these 3/8"-24 male fittings too ?)
1x pipe from booster to splice into the rear brakes.. (i will need to find an appropriate spot and cut and put a fitting on unless i can make a pipe to where it originally terminated near the MC) (pressumably male 3/8"-24 male to 3/8"-24 female)
and obviously run the vacuum line with the one way valve in it
is there anything i have missed ?
