vw_mad said:
Will get it checked out and see .
It is really easy to check yourself, I record the pressures on a whiteboard in my garage along with when I last did valves and oil change. You can get one in Halfords for about £25 and loads of articles on how to go about doing it. Just do it cold, I put down to taking my plugs in and out the hot engine as to why I just stripped the threads on the head, along with cheap repro plugs with very sharp threads, stick with Bosch next time (Time-Sert fixed the head though so well chuffed).
I would check your own compression first, see if you have a cylinder / valve issue then get the timing and valve clearances done (again easy to do yourself) and then take it to a rolling road to get the carbs tuned and take it from there.
My story was going to be 1776 last year but having put on dual Solex carbs (build quality sucks) and a quiet pack exhaust I am going to go 1600 again when I replace it this Winter, it suits my pace of life and budget and the change from stock carb / exhaust was enough to make it perfectly speedy around towns. People see a van and assume it is slow, why do anything to prove them wrong!
My theory was also more power in the engine, more strain on the gearbox and more opportunity for wear and tear. I also want to remain 'serviceable' in the field and get things fixed if I am away rather than wait for custom parts. I would love to build up a stroker motor just not for the van (I sold my Fastback a few months ago that was the target car now I think I will get a buggy next Summer instead ;-) ).
Good luck with whichever way you go, options are endless and cost is limitless, do not forget to consider the changes you need to make to the drivetrain / brakes and other bits that may feel the pain from having a touch more power.
