as already said the list is endless but if you want to look yourself to see if its worth going any further ....start with the bottom six inche,s of the van all the way round youre looking for rust,rot and filler in the sills ,steps front skirt, rear corners,check the following
1..window screen bottom panel swage line {were the window wipers are}
2..front axle and were it bolts to the chassis
3..front chassis legs
4..front x member
5..underside of the front steps
6..front wheel arches underneath and inside the cab lift the carpet look at the front floor pan inside
7..bottoms of the doors
8..sliding door bottom and the bottm chanel it runs in
9..rear wheel arches
10.. rear doors
11..battery trays and rear chassis legs
12.. engine ,does it have one, does it run ,is the oil clean, any signs of it being looked after,
13 gutters, pop top if it has one
14..paperwork, history,bills and reciepts how long have they had the van ? why are they selling it ?
now this is just a basic check list to give you somewhere to start so you can sort the wheat from the chaff, if the following check out okay then you can get someone who knows these vans to give it a good looking at
happy hunting ... :mrgreen:
