SteveW4130 said:
K@rlos said:
Suck it and see is not the way to approach things.. A stock pump will put out 7-8psi at speed, if the pump puts out too much pressure you’ll at least end up with a **** running engine or worse a fire when the carbs get overwhelmed, flood and puke fuel out the top over a hit engine. A suitable electric pump set up is ideal but If you really want a stock pump then you can lower the fuel pressure buy taking material off the pushrod.
That’s incorrect, on a stock, original mechanical pump the fuel pressure is pre-set by the spring inside the pump itself. This specific spring gives a pressure reading of around 2.5-3 PSI regardless of RPM. What does change with RPM is fuel volume, the push rod stroke determines the volume and the float needle valve controls the push rod stroke. When you shim the fuel pump base you are reducing the amount of push rod stroke thus reducing the volume. The pressure will only drop when the volume has been dropped too much and the carb/engine is requiring more fuel than the pump can deliver. The correct way to change pressure (without an external pressure regulator) is to ensure the spring is the correct one, previously the rebuild kits contained the wrong spring and the pressure would be high. The latest rebuild kits from Wolfsburg West contain the correct spring and the fuel pressure is around 2.5 psi.
A stock fuel pump is easily capable of fuelling a bigger dual carb’d engine. I run dual carbs on my beetle engine using an original, rebuilt fuel pump without using an external regulator.
Reproduction mechanical fuel pumps are very poor in comparison to an original Pierburg fuel pump with fuel pressures wildly out and poor diaphragm material causing premature failure which I think has also caused a bad reputation for mechanical fuel pumps.
Just for future reference, I am also a Steve W :shock:
This post however is not one of mine even though the thought process may have been identical, the delivery was far tooooo eloquent and precise. This is rather a scary thought boys and girls innit :shock:
I wonder if we’re related? Do you drink a lot of wine ? Or Stella ? :roll:
Ozziedog,,,,,,,two Steve Ws, don’t bare thinking about :mrgreen:
