two exhaust issues
shiplee123
Nov 30, 2012
1,763
6
East anglia
Hi just thought id check all our motors oils and waters today. Done the first two then onto the bus. Oil fine and just decided to have a poke around . When i purchased the bus i was aware the exhaust had blown somwhere and today i noticed a metal bracket / collar which attaches the exhaust i think to the back box had come apart. It seems as if tho it should be attatched with a jubalee clip or similar. What part do i need to attach it ? Ill post some pics
The other thing i noticed was a piece of pipe missing which i believe is part of the heater pipe is that what it is and what part am i needing for this ?
Sorry to b a pain image new to vw busses
At a miniumum you're looking for these:
http://www.machine7.com/section.php?xSec=2464" onclick="window.open(this.href);return false;
and these:
http://www.machine7.com/product.php?xProd=575&xSec=1409" onclick="window.open(this.href);return false;
Also these:
http://www.machine7.com/product.php?xProd=603&xSec=1425" onclick="window.open(this.href);return false;
and these:
http://www.machine7.com/section.php?xSec=3244" onclick="window.open(this.href);return false;
Do you have the cardboard pipes that run from the fan housing down to the heat exchanger connection? Also, you've a bit of tinware to put back in that area don't you?
Thanks for that ill write all them down. I think the rest of the pipe is there. I wasn't aware i had tinware missing. Where abouts is that what?
Looks like you're missing a bit that looks like this (the one in the link might not be the exact one that you need):
http://www.vwheritage.com/vw_spares_Tinware-rear-black-stock-AC119543_act_shop.product_pID_64109_lang_EN_country_GB.htm" onclick="window.open(this.href);return false;
And part 23 in this link:
http://www.vwheritage.com/vw_act_page.render_pageID_274_lang_EN_country_GB.htm?startRow=1&startPage=1&maxDisplayRows=15&dcCfcSortSelect=PopularitySort|asc&dcCfcBrandFilter=excluded&dcCfcOriginFilter=excluded&dcCfcPriceFilterLow=excluded&dcCfcPriceFilterHigh=excluded&searchText=&classicSearchText=&classicSearchType=" onclick="window.open(this.href);return false;
Your engine will run too hot unless you get the compartment sealed up properly
Ill have to have another proper look when its light tomorrow. From memory there is a large length of thick pipe running underneath the van front to back so i think its just that small section missing.
Anyone any thorts on the collar ( first couple pics ) how do i connect the two pipes together
Just had a proper look under the bus. The cardboard type pipe runs front to back and seems heat exchanges r there its just the flexy pipes are missing... Both sides :(
Just noticed this on jk
http://www.justkampers.com/113-255-355-heater-tube-bundle-kit.html" onclick="window.open(this.href);return false;
